[ODIN] Official Froyo ED01 packaged custom ROMs w/Root - Updated 06/12/11
Ok quick question for everyone.
I haven't been on these forums for a while because I went back to grad school, so I haven't tinkered with my Fascinate in a while. I am still on SC 2.9.2.
With the creation of the new ODIN packages (thanks Landshark), am I to understand that I can ODIN the new commrom 2.0 without wiping? I don't have titanium backup and have never used it, so I'm not really sure if it is worth getting it and backing up then wiping. I have a bunch of market downloads and amazon appstore downloads that I definitely don't want to lose the data from.
Thanks for any help. I've always used ODIN and feel that going this route would be most familiar. Nevertheless, I'm ready to try something new (Titanium backup) if I need to, but I'm just not sure how to truly use it to back up my apps and app data, specifically.
quick question... if im on ED01DB_DO_SHARK.tar but have some problems where i'll be in the market and it backs me out all the way as if pressing the return key, should i reinstall using same one or wipe cache/davlik and use the non wipe file???
I would recommend getting titanium backup anyway. That way you can create a backup of all your apps in case something happens. You CAN go to Comm ROM 2.0 by using one of the no wipe versions, it is just not recommended by the ROM developers. As always, flash at your own risk.
The no wipe version will wipe your cache and dalvik. Before you do that I would recommend doing a thorough cleaning of the soft key area of your phone. Seems the soft key buttons of this phone are real sensitive to being dirty and will sense the dirt, oil, and grime as being pressed.
anyone else having a problem where the touchscreen becomes unresponsive and you have to hit the power button off and back on quickly to get the touchscreen to work again?
Re: [ODIN] Official Froyo ED01 packaged custom ROMs w/Root - Upda
Hey guys got a few questions for yas. Im currently on EB01 Debloated/ Deodexed W/ clockworkmod, it was one of the Odin packages the was put together by DroidXcon back in i think Feb. I want to upgrade to the ED01DB_DOx_SHARK.tar file on the first page. I have ODIN already downloaded and i had to download samsung drivers last time i flashed, will i need to redownload them? im running Win7 64bit not sure if that helps or not. also when i finished with the odin i was instructed to add the file update.zip to my SD card. Is it ok to leave that there or should i remove it before i upgrade? after i flash the new file, i will close down odin and let the phone fully load then shut it back down and reopen odin and add the latest CWM file? as the directions say. Is everyting on the OP up to date and the correct files i need to get this party rolling :) When i get this finished i would like to add a new theme, which themes will i be able to use with the ED01DB_DOx_SHARK.tar that i'm going to install? oh and one more question, this wont wipe my data right? That's all i can think of right, Thank You in advance for the help
Is there a CWM 3.0 that isn't VOODOO? Also, is there a ODIN version of Adrynalyne's ED01 Debloated/Deodexed? I don't want the EC01 radio and such. Thanks everyone!
Hey Just wondering if anyone could help me out regarding my post above. Thanks again
You will not need to redownload the samsung drivers. The ones you had before should work fine. You do not need the update.zip file with the CWM you will be flashing from this thread. So you can safely delete that update.zip file you have on there now. It doesn't hurt anything to leave it on there, so basically your choice. Everything in the OP is up-to-date. Check JaeKar99's themes thread and use any themes that are listed under the 2.2 section that do not specifically say they are for Comm ROM 2.0 or EF 3.6.
http://forum.androidcentral.com/ver...s-roms-kernels-boot-animations-7-11-11-a.html
Reactions: Bdubb513
Hey shark would the black alien theme be ok to use?
Check your PM.
Just wondering if anyone has had the problem with the power off charging? I have tried everything but when I power down the device and plug it in the battery charging icon freezes and I have to do a battery pull to get the device to turn on... any help would be appreciated.
running black alien by the way...
Same thing is happening to me, I may have to start over from scratch.
Helllo....I had the same exact problem awhile back. Id turn the phone off to charge and then Id get the grey battery symbol with the progression symbol in the middle. It never turned green and it would require a battery pull to start the phone. After alot of posts, JaeKar recommended that I change the kernel to Comavolt. Once I did that, the battery would charge with the phone off. Goodluck, that should straighten things out. Just ,make sure you install the correct Comavolt kernel for the CWM you are using. If you need help with changing the kernel, there is a most excellent tutorial by SheepdogElite on first time rooting which as you go through this sticky, you will see how to change the kernel....
ruatahmar
