[Odin][Rom][6/20/11]AC's Altered Beast **Alpha 5** EE4 based
Great Rom, but my question is if there is a way to still use the Camera even after the battery reaches 15%>?
So all you have to do is follow the steps at the begining of this thread, because if so than rooting sounds a lot easier than I thought.
Yea man you literally follow the steps, I was really intimidated but found that not only were the instructions easy to use but DroidX included pictures so as you go its easy to make sure you are doing the correct thing!! Takes like 20 minutes and you are done! Afterwards you are rooted,debloated and flying on a Voodoo kernel
[note]
Op has been updated with Alpha 5 , this is to be flashed with Clockwork, and you will need to do a data and cache wipe. If you do not know how to flash this please hold off till tonight or tomorrow i will be opening a new thread and closing this one, thanks everyone for your patience
[/note]
[note]
[/note]
Sweet!! Loading it up now. I will report back!:D
Great man. Downloading. Thanks again for all the effort. Hope I don't brick if I haven't taken the EE4 ota...
Let's find out :-)
[note]
[/note]
Awesome! Been wanting to pull the trigger on this as the stock Droid Charge firmware blows lol
When i try to do the data wipe, it hangs at the android.secure file. I have to do a battery pull and reflash EE4 with Odin afterwards. Any ideas?
Up and running! Sweet looking. Sucks I still gotta downgrade to ED1 to get the new radios, but it'll give me something to do later. Thanks again.
From ED2 running AB 4.1.1 on jt1134's voodoo kernel (or maybe imnuts...)
De-voodoo-ed (just in case)
Wiped Data/Factory Reset
Wiped Cache
Wiped Dalvik
Installed AB5
Reboot.
Slow going at Droid eye (patience is a virtue)
CAKE!
Edit: Ok, the 3D app list is awesome
I'm currently running GummyCHARGED 1.7.5 with EE4. So alI need to do is boot into Clockwork, do a factory reset, and flash AB 1.5 from the SD card right?
yeah there is a newer clockwork that fixes that ill post it with the new thread i make
yeah that should work.
[note]
[/note]
I love you!!! :-*
Putting a Poster of DroidXcon on my wall!!!!
[note]
[/note]
Installed Alpha 5 and it is sweeeeeeeeeeeeeet. I'm such an incredible noob that I needed help installing it, or might not have needed, the instructions are so good, but was super happy to have it. I'm building a small shrine to DroidXcon in my living room, the shrine should be out of Alpha and into Beta later today....:)
Anyway, my phone was a mess, lots of problems including no data, constant forced closures, etc., this fixed it all!!! This new version has a zillion (well, not quite) little touches I like including beautiful new icons in the toggles in the notification bar for WiFi, Bluetooth, GPS, etc. I think if i had to go back to that horrid black orange Halloween theme that comes stock I might puke!
I don't think I've had a single "forced close" since I installed this, something I had routinely gotten before.
The only tiny complaint I have is the android guy on the swype keyboard. My eyes stink, one of the main reasons I rooted was so I could make the system font bigger, and the android guy makes it a little harder to see the kb.
GREAT JOB DroidXcon, donation coming your way so you can be as incredibly helpful to others as you have been to me!!!!
Joe
So I had AB 4.1.1 and Wireless Tether work. I tried GummyCharged 1.7.5 w/EE4 and it quit working. Went back to AB 4.1.1 and it worked again. Just updated to AB Alpha 5 EE4 and it doesn't work again.
Wondering if anybody else is having this issue?
websitedesig101
