[Official] CyanogenMod 7 discussion
Wireless tether doesn't work with CM7.
There is a built in tethering service though. Go to Settings/Wireless & Networks/Tethering & portable hotspot.
Enjoy! It should work.
searched thread, but did not find answer to following:
Is there a way I can get Sprint TV back after installing CM 7?
Install Sprint Visual Voicemail on CM7 Original Link
1. Download the Sprint VVM 5.1.0.48 Titanium Backup zip: Download
2. Extract the Sprint VVM 5.1.0.48 Titanium Backup zip to the root of the SD card.
3. Download & install Titanium Backup from the Market.
4. Launch Titanium Backup and make sure Sprint VVM is removed (if not, use Titanium Backup to remove it).
5. Install the Sprint VVM (/sdcard/sprint_vvm_5.1.0.48.apk).
6. Launch Titanium Backup, select Sprint VVM, select Restore and select Data Only.
NOTE: There is App+Data but it doesn't work.
7. Launch the Sprint VVM and "Compose" a message to yourself. It will test send and receive functions of Sprint VVM.
8. Enjoy
I tried this earlier today and works 100% :)
You will still receive 9016 text messages everytime you get a VM but you can use Handcent to block them.
Please help - at step 6, but there is no back-up option for VoiceMail. I am assuming that the backup folder was in the .zip folder downloaded in step 1, is that correct? I think the folder for TiBU was either modified or delted as it does not show a restore file.
Technical Question
So I rooted my evo using unrevoked with Cyanogen7, however I didnt flash the newest ROM version of Cyanogen. So my question is if I want to install the newest ROM, do I have to reflash everything from the first step, or can I just load the zip in the SD card and just flash that one file?
You just need to head over to cyanogenmod website and download the one you want. Then boot into recovery and flash.
Any idea on when or if we will get 720p video or higher res stills soon? From what I see that is really the only thing missing now. The stock camera app was really quite good.
If you are having WiMax issues that are not fixed by rebooting, try reflashing the rom. If still the issue persists fall back to RC2...trust me you rather have something as important as 4G working than unstable.
Thanks for the reply. I found that I just ran the RC3 installer over my RC2 install without wiping. I thought I read somewhere that you didn't need to do a fresh install if you already had RC2 working. I installed a fresh copy and now it seems to be working well. I just wish it actually was able to tell me what my signal strength is. Sometimes I think it should be working but doesn't connect but I might just be in an area that doesn't have the best signal.
But overall I'm loving this rom. :)
There are way too many posts for me to read through and see if this problem has been addressed or not, but my vibrate does not work for incoming messages and emails, is this a known problem that can be easily fixed or something new? I'm running the newest CyanogenMod 7 rom.
Its said that you don't need to wipe between small cm upgrades but I tend to do just for safety. Glad I could help.
Sent from my PC36100 using Tapatalk
I have not heard this issue but I suggest possibly wiping and reflashing...could solve bugs along these lines.
Can anyone post the cm7 link for EVO stable version with everything working. Where I also see screenshots of the rom also
rosannejoy555
