[Official] CyanogenMod 7 discussion
So does this mean the new nightlys will be CM8......lol? I just got so use to flashing everyday. I'm a flashing addict, lol.
I don't know if your situation is the same as mine, but perhaps there are some hints in my thread about having troubles. It would only behave with the old version of ClockworkMod. I've switched to Amon_Ra's RA Recovery for future attempts. I'm holding off until they squash the EVO bugs before switching.
Yeah I like Amon_ra more but all my nandroids are with Clockwork...which I'm using the newest version of.
What's new on the lately release of CN7stable
before i do anything i would like to know any changes and if it is worth it?
Fix compcache (android_vendor_cyanogen)Fix "Add skip_themes directive to build process" (android_vendor_cyanogen)cm: Bump versions for 7.0 release (android_vendor_cyanogen)Update Russian translation: File Manager (android_packages_apps_FileManager)Updated Italian translations (android_packages_apps_CMUpdateNotify)Update Russian translation: CMUpdateNotify (android_packages_apps_CMUpdateNotify)Update Russian translation: Contacts (android_packages_apps_Contacts)speedy: torch: enable low brightness mode (android_packages_apps_Torch)Add skip_themes directive to build process (android_vendor_cyanogen)recovery: Prevent the users from doing stupid things. (android_bootable_recovery)Fix miscellaneous typo (thanks Xavierdarkness). dialled -> dialed Dialled is not technically wrong but its used more in the UK while dialed is US. I kept the string names the same because (again) it's not technically wrong. (android_packages_apps_Contacts)
AND, it's a final release.
Installed again...restoring only my apps+data. One thing I noticed is that TB sure backed up a lot of sense apps...bleh.
All is running well on 7. GPS seems to have worked...it gave me directions. Also, my 3g data speeds seem faster than cm6.
also it seems my phone isn't ringing.... the dialer works when i try to call someone but someone calling me goes straight to voicemail... help?
Update,the install went great! Now my 3G speeds went down again,I was getting 500kbs-1mbps,what can I do to improve my speeds?
Sent from my PC36100 using Tapatalk
Running on an evo4g. My home button doesn't work and when I try to turn on wi-fi it just cycles right back off. Only two issues I've found so far.
I have seen the home button issue on a previous nightly, not sure which one though. I re-wiped cache/dalvik and reflashed the ROM and I never saw it again. Not sure why it came up in the first place though.
Only one issue when I upgraded to the final release. I can NOT add my mlb11 app as a 4x1 widget. Now I cant see my cubbies score streaming, unless I open the app.
It sounds like CM7 is trying to save you some heartache there friend... ;)
rosannejoy555
