[Official] CyanogenMod 7 discussion
7.0.1 on its way
CHANGELOG
+### 7.0.1
+* Common: Fix fling velocity of status bar and ADW swipe - Sven Dawitz
+* Common: Fixed webview layout bug (issue 3229) - Zinx
+* Common: Fix GVoice-opens-twice bug - Zinx
+* Common: Fix issues on all devices with DNS resolution failure after some time - Zinx, various
+* Common: RTL improvements - Eran Mizrahi, Eyad Aboulouz
+* Common: Fix crashes in Arabic locale - Eyad Aboulouz
+* Common: Add Arabic keylayout - Eyad Aboulouz
+* Common: Improve ADWLauncher scrolling/zoom performance - Pavel Kucera
+* Common: Fix excessive memory use when appending to textviews - Cyanogen
+* Common: New wallpapers from the CM community (CC License, see app for credits)
+* Common: Option to disable vibration while in-call - Evan Charlton
+* Common: Add long press option to status bar widgets for settings - Alex Avance
+* Common: Compact carrier and status bar tweaks - Nihanth Subramanya, rorifree
+* Sholes: Fix connectivity loss bug - cvpcs
+* Speedy: Fix keyboard lights - JD Horelick
+* Glacier: Fix backlights - Zinx
+* Glacier: fix GPS issues - Zinx/QCom
+* msm7x30: Fix bugs during video resume - Zinx
+* qsd8x50: Fix 720p video playback
+* qsd8x50: Unified 2.6.37 kernel - Cyanogen, toastcfh, slayher
+* Espresso, Legend: WiFi fix (HTC)
+* Supersonic: Fix GPS issues (HTC)
+* msm7227: Fix GPS issues - Alex Hofbauer
Has anyone been able to get Skype to work with CM7? No luck here. Just force closes when I try to log in.
Well the nightly builds are up and running like usual. #55 has been released and I haven't even got a decent run with #51 yet.
Did something change? I went to the mirror site (teamdouche) and there wasn't a 7.0.1 but a 7.0.2. Am I missing something? :confused:
This is very weird when it first came out it said 7.0.1 and now its gone and only says 7.0.2 not sure if there is a difference. I'm going to go ahead and download it.
Sent from my PC36100 using Tapatalk
Just flashed up to 7.0.2 and Facebook still crashes like a drunk 5-year-old pilot when you try to do anything. Boo. Hope it helps battery life. It's been crazy the past couple of days.
Found an issue with the new stable release. The camcorder doesn't work when set to high or youtube. Only works with low or mms settings. Back to #51 for me.
Do yourself a favor and download Flow instead. Never look back to the rotten FB app.
Ditto. Not a problem for me cuz I don't use camcorder, but a pretty big miss in QA, I'd say.
probang
