Official: Post Droid 2 questions, get answers
The last 4 numbers I dialed are not displaying. I thought maybe "the box is full" or something so I went to the bottom of the list and started deleting numbers. But instead of making more room, older calls dialed starting to come up on the display. So I went back to the top to see if the last 4 calls were on the display yet - none of them were there!
Why is my phone doing that and what can I do to make it start displaying again the most recent dialed calls?
Also another issue, my Droid keeps freezing up. The Sticky Notes apps that are on my screen would not allow me to do any editing unless I do not use space bar to put any spaces between the words. If I used the space bar, it would freeze up. It also froze up if I used symbol keys rather than text. The phone would freeze up if I put any spaces between the words in the texting app. So I could not text anybody with words. Any sentence had to be one long word. In other words, there were no spaces between any of the words, they had to be all run together or else the phone would freeze up with the first space I would use.
After researching Droid issues, I started deleting apps off the screens til I had 5 empty screens and would have deleted some of the empty screens if I could figure out how to do that. I figured my Sticky Note had been corrupted so I started out with a new Sticky Note on my Home Screen window. That one will allow me to utilize the space-bar between a couple words on occasion but then freezes up if I try it again. Every time it freezes up, I have to try several times to exit out of the app before it will let me exit out of it.
Why is my phone acting like it has been corrupted and what can I do to be able to send a text with spaces between the words again?
Then on Monday my phone lost an hour! How could that be? I had to go into settings and figure out how to reset the time to get it back on the right time. Is that totally unrelated to the above problems? or could it be that there is something corrupted that needs to be reset? What do I do to help my phone get back to normal???
hello. i rebooted my phone and now its not working. it is stuck on a screen that says touch the android, i touch it and nothing happens. I really need my phone back to working order asap. can you help?
uOttawaGrad_22
