Ofthen no internett on wifi after using Wireless zone
nilshv
I have a strange problem. I use the Wireles zone function two times a day and connect my computer to it. After im done, i turn off the Wireless zone, and Wifi gets turned on again. But ofthen (not always...) i have no internett connection when my mobile is connected to wifi. If i turn off wifi i have internett.
The only solution i have found is to reboot the phone, then wifi works perfect. I also did factory reset on my phone. After that it worked great (didnt loose internett after wireless zone). Its been ok for 15 days, but yesterday it started again.
- I have tried ping, it says cant find the serer im pinging.
- Tried different apps, none have internett.
- Tried different wireless routers
- Looked over settings. I got a IP from the router, its connected, everyting looks ok.
I have a galaxy s5, SM-F900F
Android version : 5.0
Anyone have an idea what to do? I suspect bad programming on android/samsung, and that it is a software error.
Taylor Bag
