- Feb 6, 2017
- 99,086
- 15,793
- 113
Which Samsung device you have I can put in correct forum maybe someone else had the issue.I've tested my GPS after a system cache partition and sadly that was not the solution.![]()
No problem , my pleasure!Samsung Galaxy S9+. Thank you for being so eager to help!
How do you know that WiFi scanning is on - unless you go to the WiFi page, which automatically enables scanning while the page is in the foreground?Tapping to "turn location services on" then just re-enables wifi scanning.
Have you gone to settings, connections, advanced, and turned off what is circled?![]()
is your Google maps updated to the latest version? i believe its 10.34.3
