OTA update?
I finally got the May update a couple of weeks ago. And then, a couple of days ago, I saw posts here about a June update. I checked and, sure enough, there was an update.
Galaxy S9+ on Sprint
Sorry, here's the info. Security level dated 6/1....
Yep, just got mine for Unlocked S9 on AT&T. I'm in N.O.
Hopefully the next won't be 5 months from now..
anything new from this June security update?
I haven't noticed anything new, but someone mentioned that it took care of the "black crush" at the bottom of the screen and someone else mentioned improved battery life. I have no idea what this black crush is. Maybe I'm using the wrong term. Anyway, I haven't noticed any difference, and that includes any difference in battery life so far.
So I just picked up an S9 from ATT this week and it looks like mine is still on Feb 2018 version. I've manually checked for updates and it says I'm up to date.
Thoughts?
Go to settings - apps - top right corner tap on the three dots -tap on show system apps - and you'll see two Software Updates apps -go into each one and tap on storage - clear cache and data then check for system updates again. Repeat until you see the update show up.
Cool, I'll try that.
I just received June 1st update and it's now the 1st of July.lol. This one was BRE3 /BRF3 I thought it was ARF something?
RE: the June update; ARF4
Those of you who have downloaded it .
Have you noticed any improvements ?
Phone still runs cool etc.?
Have you noticed any overheating or problems AFTER downloading it ?
I noticed it is 750 meg -
How long did download take ?
Thanks.
ARF5 incoming for SM-G9650 (S9+ Unlocked Hong Kong Snapdragon)
October security update on October 18th. Not bad... For Samsung 😂
elijahchileshe12
