Package Disabled question
Did search for Verizon on PDPro and got this
I really wish I could tell you what to disable on Verizon, I'm sure you could disable all of those with the red icons, but I'd like to see if a Verizon user jumps on this.
Sent from my Galaxy Note 5
This is what I disabled on Verizon.
Sent from my Verizon Samsung Galaxy Note 5
One more thumbs up for Package Disabler. I have had my phone on and used it as I normally would during the day perhaps a little heavier than normal and with 18hrs away from a charger, I'm still at 43% and going strong! WOW! BT to my Gear S and low power Location Services on too.
Easily doubled my capacity and time from my Note 3.
Use Tapatalk or the desktop site
I use tapatalk and I've never been able to open or enlarge pics in posts. Anytime you click the picture it just opens up the menu to reply, thank, like, etc... I tried on desktop too and it's so small that when enlarge its too distorted to see. Thanks for trying.
Installed Package Disabled Pro and enabled the "bloatware" profile. Disabled a lot of things from Samsung and AT&T, but appears to have taken out NFC/Google Wallet. I tried restoring what I thought would impact NFC with no luck. So restoring everything now and I will manually select the obvious carrier stuff and select other questionable stuff one by one.
Not trying to start a debate on whether this app disables or hides bloatware but if it disables, why don't they show up under disabled applications. If I go to applications and then scroll to disabled, it doesn't show any app that had been disabled using PDP.
What do I need to enable for "product-tapatalk.xml" ? I used the basic.xml spreadsheet. I can't get the AC Forum app to open correctly anymore.
Not the apps fault or the basic package. Issue with Tapatalk. Had it earlier and it has been fixed it seems.
Sent from my SM-N920T using Tapatalk
Thanks for posting the updated larger pics. Have you seen improved battery life? Noticed anything missing in function, etc...?
I disabled what I didn't need. But you can enable or disable more according to your needs. It seems to run a little better,maybe slightly better battery life. If it isn't running in the background then disabling it isn't going to have any savings.
khatunkhatunc
