Package Disabled question
Does anyone here knows what app disables the rolling screen capture setting, and the software update on package disabler pro?
I disabled few more apps going off the xda thread but now my status says custom and it won't check for software updates because it says my phone has been customized, and also I can't do a rolling screen capture, I am trying to avoid enabling everything again and start from scratch, so if anyone knows I'd greatly appreciate it.
Looks like you went off on your own there. You need both software update apps and sysscope to get software updates (reboot after you make these changes ). You probably disabled either screen write or com.sec.Android.app.smartclipservice or flashannotatesvc for scrolling screenshot. I would keep all those enabled. Stick with one of the xml files in the thread if you want to play it safe and not lose functionality. Also if you post on xda thread you would probably get answered a little sooner.
Sent from my SM-N920T using Tapatalk
Thanks for the info,I don't have an xda account I just seen the post from Google search that's why I didn't ask on there i will enable those I appreciate it.
mitiku Berihe
