Package Disabler
mine didn't validate the first time on my 10+ but I tried again. try again. if you still can't do it using your original apk, since you only get three links (I'd talk to him about that) then email the dev. seems it should work since it's samsung
original apk?the link provided you meant?yes it didnt work.kept on showing empty license key bar...
when you load the apk and then validate. I did a copy paste both times of the license key. it showed both times, but only the second time worked. only copied once, but had to paste twice.
Erm ill give it a try again when im home. Just wierd... Or maybe the license is only for 1 active device?
rex9090z
