Pandora not launching in car
Their new update seems to have fixed the problem guys. tested this morning and working as it should!
while Pandora corrected the auto launch feature it still shuts down anytime you leave the app for 10 seconds for almost anything
Okay, I have a Subaru Crosstrek 2017. I have had the same problems that you all are experiencing. I was able to fix and it stays on like it did before. Here are the steps I did to fix:
1. Restore factory settings with radio. Do not click anything else, follow steps below in order.
2. On phone go to settings and apps, select pandora and clear cache first, then clear data.
3. Uninstall Pandora from phone.
4. Restart phone to clear memory cache
5. Reinstall Pandora
6. Open Pandora, go to settings, click advanced and then if LAUNCH FROM CAR is CHECKED, uncheck and save settings and start Pandora from Car Radio.
7. When Pandora opens and starts to play, close Pandora from car radio.
8. With your Pandora on phone, select settings, click advance and check LAUNCH FROM CAR and save settings
9. Close Pandora on phone and open app using Car Radio. The app on phone should start now and will continue to run like it once did.
10. Make sure you follow the above steps in order. Do not skip, as results will not be the same as mine... I'm a happy camper now.. woohoo!
THANK YOU @Jabber Jaws. AFTER TRYING EVERYTHING YOUR SOLUTION IS THE ONLY SOLUTION THAT WORKED AND I HAVE A 2015 HONDA CIVIC SI.
I registered an account just to say thank you and to suggest to everybody to try Jabbers suggestion. Finally!!!
I was also having a problem with Pandora not loading when I started my Mazda (i have a Samsung S7) this is what worked for me. I started my Pandora app on my phone, in the top left you will see 3 lines, tap on it, go to settings, look for Advanced, tap Advanced, to to Bluetooth Devices, check Launch from car, bingo, bango, I was back in business. One last thing, after you do all of these steps, restart your phone, good luck
jestyulobe
