Parallax 3D effect on lollipop 5.1.1 not working anymore
Hello engineeryajeeb
I read your message yesterday.
Today I also got a new message for updating my android and it seems fixed here too.
Parallax 3D effect resolved in new update lollipop 5.1.1
Finally :)
Greetings
David
Ok guys first of all sorry for my bad english. im here only to help my brothers. So i created an account today to share solution of this problem.
In last update Andriod 5.1.1 Parallax Effect and Undo Autocorrect while pressed backspace in keyboard were gone. I Reset my phone to factory setting also wipe the data and setting from recovery option but the result was the same. What i did i downgrade my 5.1.1 a little bit i mean i download the 1st stock rom of android 5.1.1 and flash with odin, all the feature of my Edge is now working perfectly fine. Parallax and keyword all the features are working now. No knox Tripped nothing. Full of warranty.
I suggest you to do downgrade but remember guys download only first release stock rom 5.1.1 of your country and REMEMBER do not downgrade from 5.1 to android 5.0 otherwise you are going to brick your phone.
For any queries you are welcome. :)
Thanks
You don't need to downgrade. The parallax has been solved in the new update now.
Sounds good but update hasn't been released in all the countries yet, for the time being can downgrade until the new update arrives.
If you don't have the update, go to Google store and install following app :
3D parallax background. It only costs 1,16 euro. You don't have to downgrade. It's a lot of work to downgrade.
Yes!!! :)Last night i updated my Firmware to the latest Update, everything is working perfectly and smoothly also saw the new feature of Apps Edge really nice one. But unfortunately in keyboard "Backspace undo Auto-correct Word Feature" is still missing.:-\
I'm in the UK on O2 and recently installed an update that was pushed to me (5.1.1), my paralax now works again.
Hi there
Just got a new software update for my S6 (today Friday 16th October) which fixed the Parallax Effect Not Working error that I got after I had the 5.1.1 update.
It wasnt the Marshmallow update as it still says its 5.1.1
D
Hello 1goodfella1
Good that it works again. It is a lollipop update, not the marshmallow update. The last one is rolling out now. We have to be patient :) regards,David
Hi.. that must be because you use Theme on your mobile. Some themes don't include motion wallpaper mode.
So when you apply them, they will disable your motion mode for theme.
Since there's no toggle switch for motion when using theme wallpaper you can revert your theme back to default theme, after that you need to reapply your preferred theme, then the effect will reappear again.
Hope that will help you.
xatvet7788
