Permission difference between running app from screen v.s. running from setting window
Finalpredator
On pixel 3a (probably not limited to this model), I met this strange problem. I have an app that would run if I long press its icon then go to "basic info" then select "open". But when I try to run it by just clicking its icon in my phone screen, I got a "app isn't installed" error.
Is Android system starting an app in different ways depending if I click its icon or run it from "basic info" window?
Extra info: the app is a game made through Unity. I tried multiple different builds (including signing with both default debugging key and production key, building full game, building just 1 scene, etc). All led to the same result that the game will only run if triggered from "basic info" window.
Welcome to Android Central! Is this an app you're developing, or is it an app you sideloaded from the web somewhere (rather than from the Play Store)?
OK, I moved this to the Software Development forum for more specific traffic.
Jon OapostraphyBrien
