phone appears completely bricked, need help asap!!!!!!
It sounds like youre not flashing the correct roms for your device.
You need to slow down and read more before you make a new paper weight
And twrp works just fine. What version are you using 2.4.4 is the lat3st and it works great. Cwm is old school.
And lesson 1 before you flash alway make a nandroid backup.
And most roms skip the md5 check. Not an issue.
Double check that youre flashing the right roms. Id lean towards incompatible roms vs your recovery. If uoh want to be sute go to xda and search your device under android development and you'll find lits of good roms. They may link you to goo but I would advice yiu to not blindly shopping through goo as you being a noob could easily glash the wrong rom seeing ir see nexus and flash the grouper or tilapia instead of your actual model.
Sent from my SGH-I317M using Tapatalk 2
smartcooky
