Phone is freezing
  • Thread starter Android Central Question
  • Start date
A
Can anyone help I installed the latest update and now my phone is freezing and give me a popup that says gear s has stopped when I acknowledge it then the phone unfreezes for a little bit. And it is killing my battery
Rukbat
Retired Moderator
Feb 12, 2012
44,529
26
Try restarting the phone.
If that doesn't work, bring it to your carrier and ask them to please reflash the update. (Only the update, not the whole ROM.)
If that doesn't fix it, they have a liability issue - they broke your phone. They should replace it. (Make sure you back up anything important before bringing it to them - apps included. See Backing up an Android Device.)
TechBro
