Phone radio draining battery after converting back to sense.
Jul 2, 2015
4
so i recently coverted back to sense using viperonem8 4.3.0.Ever since phone radio is draining my battery when the phone is asleep.I used gsam battery monitor to find this.When i turn on airplane mode it goes away though.Currently running supercid original cid is HTC__621.Firmware 4.16.709.9.Pls help
Welcome to the forums. Did you do a factory reset after reflashing the stock ROM?
I just converted back to gpe and everything is normal.Ill just use gpe for now then....
Did you flash any firmware when you went to GPE ? If so you probably flashed a radio for it and you would need to flash the updated stock firmware when going back to Sense.
Blakes7
