I wouldn't worry about it right now, Voodoo is for performance but it's in its infancy for froyo on this phone, not a big difference
Ok thanks...again to EVERYONE, I appreciate your patience and help with my issues.
yeah you should have have heard a womans voice,,,
do me a favor and pull down your notification bar, does it say 2.9 in the upper left hand corner under the toggles
actually it does not, it says 2.8
The only problem I had with eb16, and the only one Adrynalyne could reproduce, was not converting Voodoo. I suspect the other "stability" issues were mostly poor troubleshooting skills, I'd be surprised if anyone had issues after formatting the phone. I'm still running eb16 for the dummy tether module, have been since 2.8. I just use eb01 to covert Voodoo then reflash eb16
You don't usually, it's enabled by default and converts when you reboot
No disrespect, but I was on Voodoo before my friend gunner, I've flashed a few kernels![]()
