Pixel 2 Camera
Just to be clear....this does NOT work on the Snapdragon variant, correct?
I would so love to get my hands on a working version of this apk for S9+ with Snapdragon
In luck... follow the link I provided for the camera and download this version. It works!
Thank you for downloading Google Camera 5.1.018.177624777 (READ NOTES) (arm64) (Android 8.0+).
Odd, I keep getting App not installed.
The old version that he posted works. The updated version does not. The old version of the apk does not have portrait mode or HDR control.
World you mind posting a direct link? I can't seem to find the one you are referring to...
It doesn't look like the link posted. Is this working on a snapdragon S9+?
Yeah, that's the one that's not working for me :(
Is your unit a Snapdragon-based unit?
Don't worry, it's not the newest version with HDR+ anyway. It's a standard HDR version of google camera. One thing I've noticed, if I try to select to install from the pull down shade, after the file downloads, it won't install. If I go into my files and select the file installs with no issue.
BrüZZi
