Itsa_Me_Mario
¯\_(o_o)_/¯
- Feb 19, 2018
- 1,680
- 0
- 0
I hear that, but why? Why do that? Why run off potential customers? Why are they copying Apple and doing it poorly?
Because real world consumers do not care about a 2% change in battery capacity and some of them do care about wireless charging, now that iPhones have it, so that's an obvious trade that every OEM would choose the same way. It's very easy for us to fall into the trap of thinking that because we in the forums like or dislike something, that the market in general feels a similar way. It usually doesn't.
To me it seems like you're looking at the 2% battery capacity reduction as if it is catastrophic, when really it's still likely to be a net increase in battery life with an obvious value add in the form of the convenience of wireless charging. The below is contrasting how I would try to explain the OEM's reasoning with my interpretation (hopefully I didn't get it wrong) of your comments.
To me it seems like you're also looking at the notch as if it's defacing the device, even though it is adding more utility to the device. Most consumers are going to be in favor of gaining more screen real estate, just like they're in favor of gaining wireless charging functionality. The only way with current tech to add that additional screen real estate to the top portion of the device is with a notch. Essential, Apple, Google, LG, OnePlus, etc. all realize that and that's why the current generation of phones all took that path.
The Note 9 took another path, which is to minimize the top bezels. The display is 5.76" tall, but the top 50ish pixels are being used for notifications, meaning in most usage, the usable area of the device is slightly shorter than the 5.76". The usage of a notch to remove the notifications and status icons from the usable space increases the amount of space usable by content, all other things being equal. It's the same idea as the LG V series' 2nd screen they tried a couple times, just cleaner.
The Pixel 3 XL is basically a Pixel 2 XL with an upgraded processor, a newer generation display, more screen real estate and wireless charging added in.
