Pixel 6 and Pro November Update Bugs/Fixes
  • Thread starter Thread starter Deleted member 2609113
  • Start date Start date
I am on the world wide November build, Verizon wireless, unlocked. No update yet.
Re: Pixel 6 and Pro November Update Available
The FPS is still hit n miss IMO.
So, IF you finally received the correct update, try deleting and re-registering your finger prints. Also it needs a firm press, not hard but takes a more firm press then say the s21 does. Make sure when you register your prints you get all angles of your prints.
https://support.google.com/pixelpho...-only-selected-carriers?hl=en&msgid=135866170
Am I the only one spamming the check for update button with nothing showing? That was always the advantage of Pixel was the updates went to everyone at once (so to speak). Never had an issue getting updates with a VZW SIM with my other Pixels.
I was just telling one of the other members on another forum that this is the first time that I did not get OTA s timely for a unlocked pixel on VZW. I don't know if it just happens to be a one-time thing and it'll start working normal in December. But for the last two I had to sideload manually from the Google developer website. I've also heard some were lucky with removing SIM reboot phone and insert SIM and got updates. Not sure though if that will work
I didn't know that. I don't think it can be done in Tapatalk. I'll try it with this one.
Don't see how.
Oh, maybe it's not possible in the AC Forums app or Tapatalk. It's hard for me to tell since I have Mod privileges, but I've definitely seen non-Mod members delete their own posts.
Now I may be misremembering but I thought I read somewhere in the last few days that if an update is side loaded then you won't get the next update over ota. It would also have to be side loaded.
Maybe someone can clarify.
I'm thinking it should not stop one from coming over. On previous phones I have side-loaded and received the next month's OTA. It might be just this one time with all the issues I've seen with people not receiving it up timely. I guess we'll find out come December
According to some Google volunteer experts on the Google help forum they said that side loading on the Unlocked model on Verizon was the preferred way to get back on the correct build so future updates did come via OTA.
That should all be resolved now, but suggests that side loading an update will not affect future updates OTA.
Maybe that's what I read, about being on the recent update via side loading to become in sync. Good to know.
Google did push the 0.36.A1 to every one on C2, last week. If you had updated with no SIM to 0.36 before that, then won't get that 0.36.A1 update, so you won't get this update either.
Google has really screwed up these updates catering to Verizon Wireless
I have a unlocked 6 Pro that I put the sim card from my Verizon pixel 5 in. I didn't get the Nov update during setup so I side loaded the Verizon version. When the mid November update was pushed out I got it without side loading.
I installed this update this morning. I am touring in Italy and using navigation in Maps extensively. With the update, the navigation voice has changed with the update and I dislike it very much but don't see a way to change it. Any help with this would be appreciated. Grazie
gocoronago2021
