- Feb 6, 2017
- 98,997
- 15,695
- 113
Yeah, those things come go in beta
You also need 1.21 Giga watts. Never forget the Giga watts.I want to set the charge limit to 88 percent. The built-in flux capacitor will require this for time travel.
Welcome to AC!I want to set the charge limit to 88 percent. The built-in flux capacitor will require this for time travel.
Tin foil hats are kinda' rough on radio signals (and subsequent battery drain), so maybe setting charging to 91% is a better bet...Welcome to AC!
You need the tin foil hat also otherwise it won't work
I'll check my update if availableJust received the 80% Battery Limit setting with the December 2024 update.
But still no Battery Diagnostics?
While I was hoping you would be able to pick the % to stop at (20% loss seems like a lot), I did call a local mobile phone repair company. He quoted me $130 to replace the battery (with genuine Google).Even if you keep your phone 3,4,5 years , does the maths stack up?
Lose 20% battery every single day for years to gain.... What? A few percent years down the line.
All you have done is swap the loss of 20% round.
Spend £1000+ . Get phone. Turn everything to max. Enjoy.
Otherwise, What's the point.
This is the part (the set your own % part, not the 130...) that I'm waiting for, 80% is kinda' low for a whole days' use, or gets VERY close (also not great for the battery) to empty, if you're not careful.While I was hoping you would be able to pick the % to stop at (20% loss seems like a lot), I did call a local mobile phone repair company. He quoted me $130 to replace the battery (with genuine Google).
On my wife's I set it for 95%...I read it is the last few per cent that generate the most stress. However, I would also prefer a setting to turn off fast charging for those of us that don't use our phones all the time...and a slow overnight charge is fine. Even if you lower the % it can still be stressed from fast charging. I have a Dell laptop that I decided to try the reduced % function. However, it still charged at "express rate"...I think...it was definitely warmer at the end of a charge than letting it charge to 100% at a slower/standard rate. I now leave it on "standard."This is the part (the set your own % part, not the 130...) that I'm waiting for, 80% is kinda' low for a whole days' use, or gets VERY close (also not great for the battery) to empty, if you're not careful.
Yeah, 95% is a value I can get behind the science vs. sanity balance on this one (I'm a person that VERY rarely chooses the latter, or so I've been told...On my wife's I set it for 95%...I read it is the last few per cent that generate the most stress. However, I would also prefer a setting to turn off fast charging for those of us that don't use our phones all the time...and a slow overnight charge is fine. Even if you lower the % it can still be stressed from fast charging. I have a Dell laptop that I decided to try the reduced % function. However, it still charged at "express rate"...I think...it was definitely warmer at the end of a charge than letting it charge to 100% at a slower/standard rate. I now leave it on "standard."
