Please help: How to move SMS/Phone contacts to new SIM card?
Macroblizz
9
Hello,
I've recently purchased a new phone but the SIM card is smaller than my old phone so it won't fit... :'( :'( :'(
How can I take my SMS Messages/Contact numbers and other data to the new phone?
This is my current Huawei phone:
http://www.gsmarena.com/huawei_ascend_g510-5250.php
This is my new phone I want to switch to:
https://www.optus.com.au/prepaid/phones/optus/x-start-3
I really need some help. Thank you!
I'm wondering if there's still misunderstanding here.
The Huawei still has Google services at that age, i.e. before they were not able to sell Google installed devices later.
I'm doubting a sim card would hold 183 Contacts, and if that were true they would only be a name and phone number iirc.
Screenshots would be useful, though you would want to redact / draw a line through private contacts.
Just to clarify, on a regular stock Google phone, apart from an app named Contacts (yours is People) , you could also open the stock (Google) Phone app and the third of three tabs/buttons would list Contacts as well.
I'm sure older versions of Android could still upload to your Google One / Drive account, but that's only an assumption from my previous uses.
Thanks!
I tried using Google Drive but I couldn't back up much of my phone data: SMS, contact list etc. I had to delete a lot of cache just to install Google Drive...
Google One App is not compatible with my Android 4.1.1 OS...
Thanks!
Not much is going to be compatible with 4.1.1, I was running 4.4.2 on a device and it's now completely useless :(
It'll probably just be easiest to cut your SIM card down.... it's very easy and quick to do, and that's about the only compatible option you have.
aravrajak
