I have an LG Optimus V, rooted via Superoneclick, with ClockworkMod Recovery on it. I did an LG Style Wipe yesterday that put my phone into "recovery boot loop". I had an old backup, I backed it up and didnt help. Still in the loop.
I've tried reading guides and they all talk about ADB, Emulators, Xionia, flashing, and roms. I have no idea what any of the above vocabulary means. Please help. I dont know how to do ANYTHING.
Symptoms:
Shows LG Screen then goes to ClockworkMod Recovery v3.2.0.1
Tried Battery Pull, and nothing. Reboot system now doesnt help.
GUIDE TO FIX:
Steps courtesy of Eollie from another thread:
Pull the battery out wait 5 minutes.
Put battery back in. DONT TOUCH POWER YET.
Hold down the volume down, home and push power.
Keep them held down until you see the LG screen flash on and then off.
Release the buttons.
This should put you in custom recovery.
Plug your phone into the computer with the usb cable
Using the volume buttons to go up and down to mounts and stoarage select it with the camera button.
Go down to mount sdcard using the camera button select that.
You should now see a pop-up on your computer asking what to do do with the new drive.
Select view folder.
Now download this file.
Xionia_CWMA_12518.4_VM_Recovery.zip
Once you get it downloaded DO NOT UNZIP IT.
Copy it to the root of your sdcard.
No back on the phone select unmount sdcard.
Use the back key to go back to the main screen, on it you should see a option to flash zip from sdcard.
Select it, then choose zip from sdcard choose that.
It will open your sdcard up, scroll down until you see the zip you downloaded and transfered to you sdcard.
Select it. You will be prompted with are you really sure. Select yes.
Go to the main menu again. Scroll to advanced then select reboot recovery.
It should reboot to the new recovery.
In the xionna recovery there is a option to fix bootloop. Select that and wait till its done. then reboot your phone.
Symptoms:
GUIDE TO FIX:
Select view folder.
