Please help!! No data or voice after ROM flash
aconrad12
7
OK so i installed a EH03 GB rom to my Fascinate, i did the set up, and authenticated my phone and it said it was successful. But i cant make calls, connect to 3G or anything like that, i cant even call verizon. I can only connect to wifi. I did a hard reset, a soft rest, tried a diffrent rom, but the same problem keeps happening. Someone please help. I beg for any help, this is very important...please.......
Re: Please help!! Going crazy
Did you do a nandroid back up? If you did try restoring to your previous rom. I would try flashing a different radio too.
Excuse my ignorance (which is why i am facing this problem), but what is a nandroid back up? And what do you mean try a new radio?
I'd call Verizon from your land line and have them activate the phone.
did you try dialing *228, option1? Then the same thing, option 2.
Not trying to be an a$$ here, just trying to help...is your data connection actually turned on? Toggle the data switch on and off and on again. Do a battery pull and try again. If you get no data after all this, not sure what else to suggest. I think you said you used ODIN to load the stock GB ROM, correct? Try it again, and make sure you follow the steps in this guide exactly as they are stated. Go to section 5 to get you back on stock GB, a fresh install.
[GUIDE] Installing a Rom/CWM recovery/Root or going back to Stock - xda-developers
shy_panther
