Wanda
- May 6, 2010
- 1,454
- 133
- 0
Try this.
rezound_ics_androidpolice_3.11.605.22 - Minus
Remember, to flash the RUU as a .zip your bootloader has to be locked and the RUU needs to be reanamed PH98IMG.zip I've heard of people trying to rename it and for whatever reason Windows renames it PH98IMG.zip.zip
You may need to consider running the RUU as a .exe. You'll need pizzadude or Mr. Smith's help for that as I've never done it that way.
Edit: I see you're looking for the Stock RUU...the link above is to an ICS leaked RUU so you may want to just Google the stock one and find it that way. Once you move up to ICS it's hard to go back to GB...hardware limitation, not because it's so much better.
