Porting Optimus S ZVJ ROMs to Optimus V ZVJ
You MUST get sprint firmware flashed while in e-mode and LGNPST......remember you will lose AAA/HA keys.
Sent from my Optimus M
You know that I've got a backup of all that ;) which makes me think that I need to find out where in the rom it's setting that value. But in the past I haven't had that problem with sprint roms.
Flashing now
I must know, are you connected to VM on a ZVJ stock GB rom? THAT, I want to know. Please and thank you. :)
What do you guys think? SHOULD model number be VM670 or LS670????? O.o these phones are exactly the same, besides the key switch....
You may have to flash the zvh radio with this it's pretty simple throw the radio in the root of the zip and add this to the update script
Code:
write_firmware_image("PACKAGE:radio.img", "radio");
right aboe this
Code:
show_progress(0.500000, 0);
unmount("/system");
Code:
right aboe this
Code:
unmount("/system");
I'm just agreeing lol yup
Looking for good cm9 or cm7 themes??? visit this site for good themes. http://forum.digitalhouseoftreats.com/
That's an easy fix as assadullah says
Ik its an easy fix, I just want to know if it should be LS670 or VM670......Once you flash this firmware, you are actually holding an optimus S......root methods are different, radio is flashed to an optimus s radio .....the phone is an optimus s with virgin mobile written on the top of the phone and a sprint bootanimation.
Code:
right aboe this
Code:
unmount("/system");
Why you going on ZVH? ZVJ is downloaded via OTA once you get data working.
No I just put the zvh radio in there unless there's a zvj radio I missed (didn't look :D ) I flashed the rom and definitely need the new radio
ZVJ has a radio yes. My ov works fine with it.
But you can still root using a Computer, cant you?
I hope so, someone tell us if there is any root method for ZVJ please. Without having to downgrade to ZVD
RAP25
