Porting Optimus S ZVJ ROMs to Optimus V ZVJ
Ohhhhh. Maybe I'll just wait for your guide. But I do have all of my wireless info saved on my computer, back from when I bricked in April and had to unbrick using s firmware :)
So that. Would pretty mc make my v an s and j can't flash opt is v Roms. Just opt us s?
What I do is get everything to run correctly in dfs to show my ha aaa keys and use snip tool to take screen shots of everything (including the hex version) and then go into qpst and backup to file. Then basically just use dfs to write and the backup and then use the qpst backup (overkill)
Sidenote got the zvj rooted deodexed to work now using the zvh radio now for that menu home button thing
i already backed up my spc, my nai, my home address, my prim ha address, and my sec ha address, my aaa hex, and my ha hex. i just copied all of them and made a document with all of them. is that right?
Pretty much
So I got the buttons switched easily just go into the zvj update zip and navigate to system/usr/keylayout and open up thunderkeypad.kl erase everything and copy this in it's place
Code:
key 2     1
key 3     2
key 4     3
key 5     4
key 6     5
key 7     6
key 8     7
key 9     8
key 10    9
key 11    0
key 158   BACK              WAKE_DROPPED
key 230   MENU              WAKE
key 60    SOFT_RIGHT        WAKE
key 62    ENDCALL           WAKE_DROPPED
key 229   HOME         WAKE_DROPPED
key 59    HOME         WAKE_DROPPED
key 139   HOME              WAKE_DROPPED
key 228   POUND
key 227   STAR
key 231   CALL              WAKE_DROPPED
key 61    CALL              WAKE_DROPPED
key 232   DPAD_CENTER       WAKE_DROPPED
key 108   DPAD_DOWN         WAKE_DROPPED
key 103   DPAD_UP           WAKE_DROPPED
#key 102   ENDCALL           WAKE_DROPPED
key 102   MENU              WAKE
key 105   DPAD_LEFT         WAKE_DROPPED
key 106   DPAD_RIGHT        WAKE_DROPPED
key 115   VOLUME_UP         WAKE
key 114   VOLUME_DOWN       WAKE
key 213   DEL               WAKE_DROPPED
key 355   DEL               WAKE_DROPPED
key 212   CAMERA
key 247   FOCUS
key 217   SEARCH            WAKE_DROPPED
# LGSI_LS670_FroyoToGB_Keypad_Initialization_Vivek_15Apr2011_START
key 216   VOICE
# LGSI_LS670_FroyoToGB_Keypad_Initialization_Vivek_15Apr2011_END
key 226   HEADSETHOOK       WAKE
key 116   POWER             WAKE
key 107   ENDCALL           WAKE_DROPPED
key 16    Q
key 17    W
key 18    E
key 19    R
key 20    T
key 21    Y
key 22    U
key 23    I
key 24    O
key 25    P
key 30    A
key 31    S
key 32    D
key 33    F
key 34    G
key 35    H
key 36    J
key 37    K
key 38    L
key 14    DEL
key 44    Z
key 45    X
key 46    C
key 47    V
key 48    B
key 49    N
key 50    M
key 51    COMMA
key 52    PERIOD
key 28    ENTER
key 56    ALT_LEFT
key 42    SHIFT_LEFT
key 215   AT
key 57    SPACE
key 53    SLASH
key 127   SYM
key 100   ALT_RIGHT
key 399   GRAVE
save open up command prompt and type
Code:
adb remount
adb push thunderkeypad.kl /system/usr/keylayout
adb reboot
If your on your phone just open up the file with es note editor and change all the spots that say menu to home and vice-versa
I think you're way ahead of anyone. haha. I don't even know how to change firmwares to zvd.
What I did was go here and download the zvd cab and follow the guide sammy wrote except switch vm670 with ls670 and zvc with zvd almost forgot place the zvh update zip on your sdcard renamed as update.zip that way when you get done running kp500 you reboot to recovery (don't forget the menu and home keys are switched) wipe data /cache and then choose run update.zip
Gotcha!!! I think I'm gonna try it out. making backup of everything and putting it on my computer first. then I can always recover using sammyz guide for zv5 if something goes wrong.
quick outline of what i'll do:
download the zvd cab. switch vm670 with ls670. use zvd instead of zv5. then wait for it to work. then root using that automated method and update to zvj. Then use lgnpst to fix the data? (I've done that before)
This is not my tablet in signature, please wait for the guide, you will save yourself a lot of time and stress if you wait.
Sent from my Ainol Novo8 Advanced using Android Central Forums
You will use LGNPST for the ENTIRE process of getting from OV fw to OS ZVD and getting data to work. It is noob proof to where there is no way to screw your phone. But it will be a long detailed guide.
Sent from my Optimus M
Correct me if I'm wrong, so when you post this guide, I can use stuff like Hydro Rom? Or stock?
JohnD8851
