Post your home screens!
Here mine with this sick equalizer live wallpaper called Audio Glow Live Wallpaper... It equalizes and tells u what song is playing
Sent from my Samsung Galaxy S3 Boyyyyyy!
Same questions for you. Because your set up is pretty slick too.
Changed things up a bit...instead of putting it all on one screen, decided to make use of multiple screens.
I just wish I could easily modify the status bar to be semi-transparent like it is on the stock sense launcher. That ugly textured grey ruins the look of it, wish HTC would get rid of it and at least make do with pure black.
http://img819.imageshack.us/img819/9400/screenshot2012112422411.png
*p.s., if this is anyone else's first ICS phone the screenshot function is a bit tricky at first. As the op wrote, you press the power and volume-down buttons at the same time. Took me a few tries to get it (phone kept turning off). Try to press them both at the exact same time and hold them down for about 1/2 second, let go, wait another 1/4 second and you'll hear/see the screenshot being taken. It'll be in your Gallery. Even easier, your last screenshot will show in your notifications... with a handy "upload" button too! I love ICS!, can't wait for JB.
Actually you can just hold the power button and tap the home button =) I find it easier then holding power and volume dow 3 seconds
True, but that sequence does not leave the resulting screenshot in your notification area for immediate viewing and/or sharing (oddly).
The power/Volume Down combo does. Quite odd actually that the results differ. For me the Volume Down method is much more useful.
@Hardrock4
The widget is UCCW (Ulitimate Custom Widget) and the theme is HTC / ICS ish and they can both be found in the play store for free. If you search UCCW Sins you will find a ton of free and paid skins.
@Hardrock4
I really like your lock screen. Is that the same widget for the lock screen?
Lock screen is just the stock 4.2 which is on the rom UKB DNA 1.0.0 I'm currently running, they also have mods that lockscreen but to do either you have to be rooted.
Bit off topic but on the subject of rooting have you tried any Wifi tethering apps, or better yet are any compatible with the DNA.
NVK
