Power Button Long Press doesn't work?
fx13
3
Previously a long (3 second?) press of the Power Button would bring up a box to power down/restart/airplane mode.. Today I went to restart my phone via that menu and found my phone wouldn't bring the box up.
Phone responds fine to single press of power button. If I pull the battery, the power button can turn phone on, and it works fine for display on/off.
Three second hold of power button makes the phone briefly buzz like it would do something, but the box doesn't open. I don't use the option often, so I am not sure when it actually stopped working.
Any ideas?
Yes, it seems to work fine is Safe Mode.
Edit: After testing safe mode, I used restart. Once it finished starting and I unlocked it, I held the power key and the box popped up, so I tried it again afterwards and it sort of flickered up then disappeared, now it won't show up anymore again. So I think maybe something starts ~15 seconds after phone powers on that causes it not to pop up anymore?
Solved: I was trying to figure out what had changed most recently, when I remembered that about two weeks ago my mother's phone was stolen, and found via "find my iphone" and I realized I didn't have anything similar running on my own phone, so out of curiousity, installed Prey.
Prey has an option in settings "Shield OFF Button : Your device can't be turned off if its screen is locked." Apparently that was turned on, and shielded the button even while unlocked.
Glad you figured it out, and also shared the solution with everyone!
Marvinghrison
