Need Help. I want to Install the PRI to 1.77_003 I got the Radio to 2.15.00.09.01 but my PRI is at 1.40_003 I tried flashing the 1.77 and was told I had to rename to PC36IMG.zip and no luck. Can any one help. Thanks in advance.
My advice... Leave your PRI alone...
No Difference has been found...
and I personally went back to 1.34
I put this out there for the Capable and those willing to attempt it...
If you really want to flash I need to see which method your attempting to use...
To be honest I just want the Fresh Theam to work right on My phone The lock screen didn't show like the Droid and I read you had to update the Radio and PRI so thats the only reason I'm doing it.
How do I flash back to 1.34? My 3g has turned into 1g since putting this crap on.....
do you only need to rename if you are flashing in a certain method?
I flashed a few diff PRI and radios with the default name through the recovery console and no hiccups I have noticed.
I went back to 1.34 and the last version of radios lately.
got a little faster, but still a little lackluster compared to before. Wifi was even slow for some reason, 3G has been slow for months most of the time. 4G is like half speed then normal, but I hear Sprint is farting around with the towers again.
I got you Breeee....
Flash this In bootloader... Rename it PC36IMG put it on the SDcard...
let me know how it goes
Sweet. thanks dude. Once my battery is charged I'll do it.. Ya.. I seriously drained two batteries within 3 hours flashing romsI need help lol...
I am currently at PRI 1.40_003 and I hear both 'update to the latest/greatest!' and 'hold off the new one suuuxxx!!'.
What does the PRI actually DO and what impact does it have on the phones operations? I have updated to the newest radio update (2.15.00.09.01) and all seems well after Baked Snack 1.8 improved battery life for me. ;-)
It causes arguements like the one your referring to...
