problem loading roms
MikeDUBS
Active member
Mar 16, 2011
41
so, i am trying to load the rom from this forum (das BAMF):
http://forums.androidcentral.com/th...2-11-605-0-sense3-0-bamf-forever-1-0-2-a.html
problem is that everytime i load it, i never get any signal after it loads.
im new to rooting (just did it today for the first time) think i need the mr2 radio. so i downloaded it from here: http://forums.androidcentral.com/th...-mr2-compatible-rom-radio-mr1-after-root.html
so i go into rom manager install the zip. go back and install the das bamf rom and when i get all loaded up, im not getting any signal.
i am completely lost. the rom looks awesome and i want to use it but right now im stuck. can't find any ideas on any searches ive done, so any help is greatly appreciated. if someone can point me in the right direction, im greatly indebted. \
To flash the radio, rename the zip to PG05IMG.zip if it's not already and place it on the root of your SD Card. Boot into Bootloader: power off your phone... Turn the phone back on by holding down the volume down rocker and the power button at the same time until the phone opens in bootloader. The zip should start running and updating the radio. Once done reboot the phone on and remove the PG05IMG.zip from your phone, or rename, or move it off the root of the sd card in another folder. If its not moved after the installation it will constantly keep trying to update the radio if you ever need to boot into bootloader again to get to recovery.
If you follow the link in my signature... oh, let's make this shorter... you need to download one of the latest Gingerbread Radios... here is a link: [RADIO] HTC Thunderbolt Radios [PG05IMG.zip] (Updated: 23 Aug 2011) - xda-developers... the latest radio is "From the 2.11.605.0 RUU"... you need to install the CDMA radio that have listed... and also the LTE radio from 2.10... and PLEASE double check the MD5 Sum code before you attempt to install the radio files.
Reactions: MikeDUBS
so, i downloaded both radios that you posted. do i flash them one at a time (cdma then lte)? do i flash them after i install the rom?
i really appreciate your help.
I thought you said you installed the ROM already... you don't need to install it again... and yes, you can install them before or after you install a ROM... flash them one at a time just as I described above.
Reactions: MikeDUBS
yeah, i had the rom installed but i had to recover an old image so that my phone would work. i can't be without a phone and i was completely lost. so now im starting from scratch again. i really appreciate your help.
i just flashed the lte radio. and am about to flash the rom back on. ill let you know how it works out for me. again, thanks a bunch
i am now "quietly rooted"!!!
got signal and 4g.
thanks for all your help. guess i just had the wrong radios. wouldnt have made it to this point without you.
got signal and 4g.
Froyo radio's don't work on Gingerbread ROMs. More than likely you loaded a Radio that only works on the old Stock Froyo ROM. It happens a LOT around here... we just try to help people here.
yeah, im on these forums pretty much daily; so i was pretty sure someone would take the time to help me out. and i knew it was something silly that was holding me back. just glad you took the time to help me out.
alwinnn
