Problem setting SMS Notifications ringtone
flyingfish901
5
Hope you can help me get unstuck.
When I try to "Select ringtone" all I see are the folders in my sdcard0.
I believe this is because when I saw the initial screen it had two choices: File Explorer and Media Storage.
I mistakenly selected File Explorer and selected "Always."
How can I get back to Media Storage as my default for selecting ringtones?
Thanks.
Samsung Galaxy S3 Android 4.1.2 Build number: JZO54K.I535VRBMF1
Settings -> Application manager -> scroll down until you find File Explorer, select it, then scroll down and select Clear defaults
Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk 4
you could also just disable notifications in the stock and download "SMS Pop up" for free and that will allow you to have/set individual notifications per contact and/or one tone overall. Works great, especially if you just want notifications and still want to use the stock app, all while having personal notification sound for your favorite people. You can find some really cool notification sounds etc off of the "Zedge" app.
Adamsapple
