Problem with Netflix
mbaha
4
Hi all, I got an Slider and my wife has a V. On the Slider, while on Wifi netflix video play is VERY slow, the audio is lagged and the picture sucks. While one my wife's V everything works perfectly.
So what is going on with my slider? any ideas? I have yet to activate our phones or mod them in any way.
thanks
thanks
What kind of router do you have? The slider is 802.11n, while the V is 802.11g. Some routers run like crap when running in dual G/N mode, you may want to configure your router to run on G only. Also, download an app called wifi analyzer, and find a wifi channel that is not being used and seperated by at least 2 channels from everyone else. 1 6 and 11 are the usual defaults youll find people using. Change your router to the channel you find most seperated from everyone else.
You can try an older version 1.2.2 of the Netflix app to play videos at full speed on the Slider. However there is a green bar at the top of the screen. Here is a video demonstrating this version (starts at 6:57 in the video).
[YT]http://www.youtube.com/watch?v=AFF3GU0BwWU&feature=player_detailpage&list=HL1323057328[/YT]
I'm running an all G network. I'll looking to wifi analyzer, I should have tried from work as well
Yes, I had tried the latest version from the Market (as of 12/04/2011) but the audio was out of sync and the video ran a bit too slow. I am running it on wifi as the phone has not yet been activated.
If your rooted, use a file explorer that can mount /system as r/w such as root explorer and try the following changes ...
Go to /system/build.prop and make the 2 lines below, look like I have them
media.stagefright.enable-player=false
media.stagefright.enable-http=false
Save, reboot, see if audio is better.
Cool, where do you find version 1.2.2?
thanks
1.2.2 looked terrible on my Optimus Slider (VM). Green bar on top, and a weird sort of double-image.
1.3.0 works great though. Thanks for the link!
Hey guys, this may be my first post, but I thought I would chime in. I tried to install a previous version of netflix, all of them actually, and I cannot login without updating even with the adjusted apks. This may be something we have to wait for from the Netflix folks (if they put any focus on older hardware compatibility with their next update).
Sent from my LG-VM701 using Tapatalk
Is your phone stock? I'm very envious... 1.3.0 is lagged for me. :( Seriously lagged. I've rooted and installed the Gelato ROM and the Ginger... kernel. With my Optimus V, the 1.2.2 netflix version was flawless. No green line and everything synced.
I miss my Netflix!! (Okay, so I can still watch 1.2.2 on the Slider, but the colors are kind of funky and I have the green bar.)
1.3.0 works fine with my Slider and I also have Gelato and the Ginger Kernal...but I also have flash installed on my phone? if that makes any difference??.. perhaps TerminaMorte does as well?
Hmmmm.... I had Flash on my Slider but I uninstalled to see if it would make a difference. Which version of Flash do you have? And... what is TerminaMorte? I tried to search for that in the Android Market but I didn't find anything. :confused:
Thanks!!! :)
Ah.... HA HA.. I've done that before on a different board (Kindleboards, to be exact). I forget the names of people posting in the thread and think that someone is posting about an app or something. :p
I'll try that Flash 11 again, maybe that will make a difference. (I hope.) Seriously, I contemplated shipping the Slider back last night. Then I told myself to shape up and quit having a tantrum. :-[ (And honestly, I don't use Netflix on my phone all that much anyhow.)
Team
Bit of an Android Rookie. I downloaded 1.3.0 onto my PC...how and what files do I install on my droid?
dont try to run netflix on this phone it doesn't work, there are some older versions that update was disabled on that will run on this phone but the color is all messed up
rfhouser
