Problems Rooting ZVJ
Hey I do t know how I missed it before but here
http://forums.androidcentral.com/showthread.php?p=1254213
Appears to be manual rooting instructions. You should try it.... At least then we'll have a more exact identification of what is going wrong
Tapatalk'n it from my VM670 running LS670ZVJ Dante Rom
I thought he tried that already O.o
Also he said he might get a new VM phone sometime this weekend.
Sent from my Optimus V running OSZVJ firmware with HydroROM on MetroPCS.
Maybe he did.. I didn't catch it if he did tho
Did u try stock recovery method that's how I root mine
Sent from my LG-LS670 using Android Central Forums
Have you tried u uninstalling and reinstalling the drivers?
Sent from my Full Android on Crespo4G using Tapatalk 2
he used optiauto and gets all the way to step C after installing the update.zip with the expected Fail the error in the OP appears... also discovered with the error still on the screen he can use adb to su and gets a # however mounting sdcard or system both fail
Opti-auto never worked for me
What ROM are you currently on. The update.zips have issue with aosp based ROMs.
nope, haven't tried either of those. haven't had time. I don't think I will either, I'm ordering either an htc one x or galaxy s3 this weekend. Which one should I go for? the one x is cheaper...
Using Bobzhomes recovery, I flashed the update.zip of zvj today. it's weird because after doing that, I still had Bobzhome's recovery!!! ?? but I had no service...So I don't know how I'd go about fixing that....
Yeah bobzhome'a recovery just ignores the radio update. You have to use stock zvd or zvh recovery
Sent from my VM670 using Tapatalk 2
If your on zvj YOU own s firmware grab a s recovery
Hey just thought of something... I think I read zvj roms work on zvh right? He could update to zvh root it with sons of korhol utility and be able to run zvj roms no problem
Tapatalk'n it from my VM670 running LS670ZVJ Baseband on Mandylion IHO ROM
fhsfayt356
