Problems with 32GB Sd Card
anon(334997)
I added a 32 GB memory card to my Infuse and strange things started to happen.
Downloaded apps would disappear
Apps would crash
I had another 8 GB SD card that I added and these problems went away.
Has anybody else had any problems with 32 GB sd memory cards?
Apps would crash
No problems here. I am using a 16 GB card and it's all good. The one thing I can think of is to check what class of card the Infuse requires, and then check to see if your card meets or exceeds that class. (Sorry, I don't know what class it requires off-hand, but maybe someone else can chime in).
I am using a standard 32gb card now. I'm not aware of a high class one as of yet. I have noticed some apps seem to be gone, but then I see that probable by the sort option they may have been moved. Other than that it's all aces.
i am having no issues at all with mine i have the Lexar 32gb class 10 and works perfect.
Unable to Play Movies From SD Card
I have a 32gb card that I have loaded numerous movies on but they will not play through my Infuse from the external SD Card. I always get the error about unable to play that format....but when I move those same movies to the internal SD Card they play just fine. I have tried them in MP4, DIVX among other formats. Any ideas?
kevin_bkt
