Problems with camera and email attachments after 4.4 KitKat update.
jackdps
17
Since the update, I cannot see pics or other attachments to email (standard Nexus email app)
It worked perfectly before the update.
Camera is not working (front. .. I can't swith from picture to video, it freezes)
Everthing worked perfectly before the update.
I deleted both apps, then re installed them, reboot, cleared cache, begged it.... no result
any solution????
Thanks
Re: Google Nexus 7 Tablet (2013) Got the KitKat update yesterday. problem with email and camera.
Same here sort of I just can't open email attachments I can't say anything about the camera but from what I hear the new kitkat camera update is not well-received
any solution????
Thanks
I haven't tested attachments in email yet, but the camera seems to be working fine on mine. I took a video, and even touched the screen to take a photo while taking the video.
doug
Mine installed without any intervention from me, or my girlfriend did it. Now I've got keyboard lag, so a factory reset may be in my future.
I checked both email attachments and camera, and both are fine on mine. Hope you get it worked out. I haven't had to do a lot of troubleshooting on my Android devices, so I don't have much advice to give out.
- Matt
What's isn't there a problem with?
Sent from my Nexus 7 2013
After Kitkat Update suddenly my Nexus 7 FHD has issues with power button. I can see the options for Power off, airplane mode etc without touching the power button? After that power button non responsive. Any body facing this issues? would like to know if it hardware problem or software problem?
Dejesus54
