problems
MrJoseSanchez8330
63
Ok so im rooted and have been switching between roms lately and now I can't get my bootstrap to finish loading. It is stuck on installing and has been for awhile. How can I fix that? It wont let me uninstall or cancel anything.
when you say the bootstrap wont finish loading, do you mean that the bootstrap app wont load from the marketplace, or that a rom you are trying to install in recovery will not load?
also, moving to Droid 2 Rom/Hacks forum
try going to menu>settings>applications>manage applications and find your market app, and force stop it, then reopen it and try again. you might just have a hang up in the market
So I tried that and it didn't work. It started loading it after I switched roms and it was laoding my apps back from my sd card. Should I just try and use rom manager and reload the rom over again?
Thanks man that worked just perfect. I was thinking about trying that but didn't know what it would do to my market and didn't want to f something up lol.
alshrmani 77
