Project Elite ROM
Gave this another try today with the 5.1 download, and it just doesn't work with my Droid. I even followed the site's instructions for installing it instead of letting ROM Manager do it. I keep having the same issues with the phone randomly restarting over and over again. I'll wait for CM7 to be done. In the meantime the Froyo PE ROM still works great for me.
K, is anyone else having random problems with camera and overheating using the browser and things?
Can anyone recommend a good kernel for V5.0.2? I've been trying the slayher 1200, Pete's 1.05, and a couple others on the download part of this ROM. Right now, I'm using the 1100 SV because I was having issues with the LV kernels and signal strength (I work in the basement). The only problem now is it's KILLING my battery. Any recommendations? I love this ROM!
If your going to use a standard voltage overclocked kernel its going to drain your battery really fast...find a 800Mhz SV kernel its still overclocked but will give you waaaay better battery than a 1.1Ghz kernel.
I have had V5 since the day it was released. And it is pretty great. I flashed this after reading an article about it on droid life. I have the RZ low voltage 1100 kernel running with it. Its extremely smooth and fast. The only problem I ever have is my phone will randomly reboot. But it is not a big deal because it only takes like 10 seconds and its good to go again. But apart from that games are fast and smooth. scrolling is smooth and the UI is pretty epic in my opinion. + gingerbread is so much better then froyo. ohh and Battery life lasts about 10 hours or more with pretty heavy usage. As i text allot ,make phone calls, check my email, listen to music, play games, and use the web several times a day.
