Pulse notification light??
Go into the Notifications area and find out what app matches the color bar. Go in and check the Clear Notification Style and see what its set to. You might have had a notification bar alert and swiped it to clear it. Some are set so you have to go into the app to clear it.
I cannot believe I did not see this sooner. This is exactly what was happening on my Nexus 10. Turns out there was a notification for "No Signal" and once I disabled that the constant "purple" light went away. Thanks Corkey!
I had issues with lightflow and not being able to clear the notification pulse so I turned it off. Now I never see pulses. Guess I need to un install it but I've been too busy. The standard notification light didn't seem to go off at the right time either.
light flow doesnt work on either of my n4's. even the dev doesnt know why. he and I have run multiple diags and came up with nothing.
Odd that it seems to work with some and not others, no?
You and the developer hitting a dead end isn't super encouraging :/
personally i try to find a way to increase this rate without lightflow as i read a lot about this app draining battery.
it's a shame that 1blink in ten seconds is obviously too slow... what's wrong at android :-/
Jon OapostraphyBrien
