PWGB/Imoseyen Force Close
bad news so i didnt like the lag in resseruction so i tried to flash PWGB and my phones bricked and the phone wont boot p at all any help please asap
Can I flash Resurection 1.0 (after wiping the big 3) over PWGB or am I missinng a step?
What if I want to get rid of the lean kernel and go back to straight PWGB, what is the proper procedure to do that since it's going back to nonvoodoo...
To answer both, you can install TSM res right over PWGB after wiping the big
three. If you're doing that and it's not working, check to make sure you're installing TSM res 1.0 and not 1.1, as that is a patch requiring 1.0 to be installed first.
To go from voodoo to non, boot into recovery and go to the voodoo menu and disable everything. Reboot your phone and it will convert to rfs. Once everything is booted up, you can boot into recovery again and flash the other kernel.
What you have to do now is ODIN back to ED05 stock. For good measure, I would repartition with the atlas 2.2 pit file, just to be safe. After that is all set, you can go from there. You flashed a nonvoodoo kernel over a voodoo enabled one. The file systems are different, this causing the problems. I know from experience.
I thought I'm on eh09 b/c of PWGB...so can I flash ehi20?
Thank you for all your help
This is weird like okay I was gona do that and I decided to try it again and PWGB was flashed?
Sent from my SCH-I500 using Tapatalk
Not sure I'm following you... Are you saying you reflashed the PWGB kernel and it worked this time? If so, you are very lucky, as I've never heard of that happening before.
reblkari666
