Question on rooting my verizon LG Vortex
i need help returning to stock. I had to get a replacement device and need to return to stock
Did you install a custom recovery or no?
If no, power off your phone completely. Press and hold volume down, home, and power. Note power should be the last button you press but hold them all down until you see a progress bar. When your phone reboots, you will be wiped completely clean, so the obvious back up should happen before any of this.
If you did install a custom recovery was it the one i linked too or a different one. If its a different one provide me with a link of where to get it and ill take a look.
If you installed the one i linked too, let wait till i go to lunch, ill have you run a nandroid restore and four lines of code and youll be done.
I have tried the latest version 2.2 of Super One Click and all I get is a message that states the Daemon has started successfully, and nothing else occurs. Can someone PLEASE help me with this?! I HAVE to remove this bloatware from this phone. My wife is constantly getting out of memory messages, and the only way to stop them is to remove the bloat.
I would try gingerbreak, it's working for the optimus S phones so it's got a high chance of working on the vortex since it's the closest kin to the vortex.
tinni99
