Questions about going to FROYO and small phone issues
ok i understand that part by my transfering songs to my sd card .. i am gonna place files i think necessary on laptop.. its fast than this cpu
man i am sorry to sound so impatient and that my part questions dont make sense ..
should i being a nervouse type place the files i dl'ed on my laptop and let it do the work so i can stay here for help
yeah in my odin directions the only thing you put on your phone is update.zip
mr droid i know i am taking a lot of time but please bear with me ,,1. i am 100% disabled combat vet from vietnam days and take about 50 pills a day and they tend to monk with my reasoning powers.but i do want to get the update and hopefully alway be around here in some form or fashion..thxs
yes i have a laptop and a desktop. the laptop is now ready for following instructions and i here on desktop can relay what my next turn should be
yes i have both but dont think i can get back to yu if something goes wrong on my end
Papa54 i would rather you use a PC if you have one available.. also pllease direct your questions to the main thread
http://forum.androidcentral.com/ver...roms-w-root-new-clockwork-updated-2-15-a.html the directions on the first post should help you through the rest since you have update.zip on the phone.... ill be working on 2.5 right now so i will be busy for like 20mins
ok i have eb01 on the ph and battery etc are still attached to phone,,i stopped as soon as i placed the eb01 on ph sd card
please direct questions to the link i supplied ,,,,and EB01 does not go on the sdcard?? are you using my directions or Adrynalynes?
Mellisa - I installed 2.2 two weeks ago and mine also only took about 3-4 minutes. I was worried that something went wrong but the update worked perfectly. I like the features on 2.2 and it seems performance (especially Wi-Fi) has improved. I did have to download and reinstall all of my apps but I did write them down prior to the update. Since I was at home connected to Wi-Fi, the download and install of all the programs went smoothly. Good luck with 2.2!
sikkman859
