Bummer this fancy notification light does not come on for mms. what the heck, unless i missed something
How well does the screen perform in sunlight/outdoors? Any problems with over heating or slow downs running HD games?
You did and it does.
Under Home button LED, Missed event you have to select messaging.
I do have that checked
Mine works...flashes green. I'd take it back if it's not working.
Is there any way to prevent it from turning the screen on when you receive a text message? I think I've gone through all the settings but maybe I missed something. The only way I've been able to keep it from turning the screen on its to completely disable messaging notifications but that isn't really a good solution.
i dont see an option to disable thta on the stock message app..i use gosms pro n i have the option to not have the screen turn on when gettn new messages..
btw how much ram mem does your phone use on average?
Like any other screen...it's dull but legible I haven't had a problem playing games..
This is consistent with what I've seen-- it's hard to tell what's using all of that RAM (likely the Optimus UI), though I never noticed a slowdown despite how low my available RAM got.my optimus g pro uses alot of the 2 gb ram mem...most of the time i have 1gb to 400mb free only..what uses all the ram and is this normal ..im only asking because my note 2 used well less than 1 gb of ram.
How do you change the lock screen shortcuts? Everything I can find says that there should be a setting for clocks and shortcuts under the lock screen settings but I don't have that option.
I believe there is an option for that within the app under settings>notifications
