Questions about the LG Optimus G Pro? Ask Android Central!
Originally Posted by shuhn72
How do you change the lock screen shortcuts? Everything I can find says that there should be a setting for clocks and shortcuts under the lock screen settings but I don't have that option.
Settings, display, lockscreen, shortcuts
Again...I don't have a "shortcuts" option under the lockscreen settings! Does anyone know why that would be? This is an AT&T Optimus G Pro and I even found a tutorial on their website that says the same thing, but the setting doesn't exist in my phone...
Post a screen shot of yours. That will help
Sent from my LG-E980 using Tapatalk 2
I figured it out.
I had the "Select Screen Lock" set to Pin and it removes the option to set the clocks and shortcuts when you have it set that way apparently. I set it to swipe and bang, there it is. Weird....
Yes I am also wondering when the value pack will be available for AT&T ? Got mine on May 9th. Anyone got the value pack yet?
I figured it out.
Oh okay great
Has anyone been able to get video out working using a MHL cable? Mine isn't working. The cable works on my htc one, but not the pro.
According to this website it doesn't support mhl.. Only wireless connections like DLNA...sad
Multimedia and Conclusions - LG Optimus G Pro (AT&T) Review & Rating | PCMag.com
Ok, answered my own question: here a chat transcript with LG support:
12:08 PM Gus: Hello . Welcome to LG Electronics U.S.A. Support only. How may I provide you with excellent service today?
12:10 PM ME: I have the new lg e980. I was wondering, if the phone supports video out via a MHL cable or only wirelessly using smart share DLNA?
12:11 PM Gus: Let me verify
12:11 PM Gus: I would like to please place you on a brief hold while I research that for you, will that be alright?
12:13 PM ME: Ok
12:15 PM Gus: Nope
12:15 PM Gus: Does not have the option I am afraid.
12:15 PM Gus: the most you could use...
12:15 PM Gus: Would be smartshare.
12:16 PM ME: Ok. I just wanted to verify. That's really essential for me. I'm glad you helped me.
I just wanted to add that the PRO does support video out via a SlimPort adapter.
How is the screen brightness? I noticed in the ATT store they had it on 100% and when I put it on auto brightness and put it on 50% is seems dark, too dark and my S4 is on the same settings yet seems super bright. I really wanted the OG Pro but the concern was battery life and support.
I do have to keep it higher than my S4. I keep it at 70%, and auto brightness checked. Haven't noticed any degradation in battery life. Btw- the phone charges very quickly. Hopefully LG will offer spare batteries here soon..
Yeah I know we talked about that and mine is still darker % wise than other phones. But like someone mentioned hasn't affected battery life. Keep mine on 65%.
Thanks guys. I find it odd that it has to be set higher but if it isn't killing the battery life then that's ok. I really want this phone for the bigger screen and .5" does make a difference which for me is odd. Still trying to weigh the options.
You guys don't lock your phones with some type of passcode.
I could never use swipe to unlock.
No problem. Its a tough decision. Great to have choices of really great phones. I am rooted and tried to push the Htc One TV app to the phone (figured it wouldn't work too tied into Sense) but it was a no go. Using the Tv guide app in the play store to substitute
The lack of MHL support has been my only disappointment. You'll love the phone. It is surprisingly easy hold. I have the HTC one, s4, and the pro (I have a tough choice on which one to return). My wife has the note 2, now she wants my pro over the note 2.
How is the G Pro better in performance than the S4 when their tech specs are the same? Unless they are running different GPUs ..but most current high tech smartphones are running the Adreno 320 GPU with the Snapdragon 600 CPU..the S4 and G Pro are at the same clock speed for CPU, with only the HTC One being clocked a bit higher.
So if anything I would expect the S4 to be a tiny tad faster than the G Pro due to the smaller screen than the G Pro.
But my question is how does the home button feel to touch? I hear its sorta pain due to its size and how high it sits up.
Sent from my SAMSUNG-SGH-I317 using Tapatalk 2
Samsung has alot of software features that slow their phones down. It doesnt matter on the cpu speeds as much now. They put time delays into their actions like pressing the home button because of s voice.
In my opinion the lg optimus g and the g pro have the snappiest ui out of any phone.
Sent from my SAMSUNG-SGH-I317 using Android Central Forums
How are people finding the camera. Some of the reviews I have read say its not the greatest...
LG Pro
Same pics iPhone 5
Blakes7
