Questions about the LG Optimus G Pro? Ask Android Central!
My phone constantly turns off by itself as if it's dead. When I try to power on it won't. The only way to get it to power on is putting it on the charger then I have to wait because it will say to to charge more to power on. My phone isn't dead it will be at full charge. I can't figure out why it is doing this and no where online does it talk about this problem.
Could someone tell me if it's possible to get the standard Android split-screen multi-view capability (seen in the new Galaxy tablet and S4) on the OGP? It looks like AT&T and LG have opted for this alternative "value-pack" update that keeps the QSlide feature instead of allowing the Android split screen feature--but I can't tell. The split screen feature is a make-or-break issue for me. I don't like QSlide at all.
Links to sources on this topic would be helpful as well. I've been digging for hours.
There is no standard Android split screen multi view setup. Samsung's is a custom Samsung thing, just as QSlide is a custom LG thing.
Sent from my LG-E980 using Tapatalk 4
the 4g on my LG Optimus Pro shut off & I cant get any calls or text, and i'm in an area where I always do. do you know how I can turn it back on?? thank you!
i have one problem with the lock screen . my lockscreen shows clock on 2 different cities the same as the photo : 40051_605.jpg and i cant change that , i want to show only one city , also i have tried changing the settings on lock screen : lock screen - Clocks and shortcuts i select clock to be bigger or clock + calendar after i tap save nothing happens , the screenlock remains the same
I downloaded 2 mixtapes on my phone, and in order to listen to them, I have to extract them. I hit the button that says extract & it says "Cannot extract files" "Extracted to email folder in SD card" I was told to try going to my settings and extract them that way, but I can't figure it out. Anyone know how to extract them?
Hi,can anyone advise a replacement compatible charger for Lg Optimus G pro F240s?can i use original samsung s3 or note 2 charger?thanks
Trying to edit the lockscreen buttons and effects:
I looked in all the suggested places, but there is no "clocks and shortcuts" or "effects" options at all. I have select screen lock, wallpaper, hidden pattern, owner info, lock timer, power button instantly locks, vibrate on touch, and make pattern visible. There is nothing else.
Did they remove this feature or stuff it somewhere else in a recent patch? I just bought the phone today...
Ok that's weird... you cant change the apps or effects if you have the pattern lock for some screwy reason.
I actually prefer the Samsung charger and bought two of them. The micro usb fits much tighter on the Samsung than the oem Lg. Works fine.
Sent from my LG G Pad 8.3 running CM11 M2 using Tapatalk Pro.
Hi, I have Optimus LG e-970. I am looking for the best voice activated app for calling/texting/emails, etc. I spent $20 on a highly rated app called EVA but it doesn't seem to recognize my contacts? Thank you!!
Hi,
Just dump my Note 2 and switch to G Pro E988. Anyone knows how to restore the backup (done with Kies 3) to G Pro?
Hello to all...I'm really considering the LG Pro. E980
Could anyone tell me if russian language among others in list of available languages ?
Hope this helps
Sent from my LG-E980 using AC Forums mobile app
How do you turn off the auto sending of LG Optimus G PRO when you have no load at all. It is already irritating that it prompts a "your don't have enough balance to send a text...etc." more that 30 TIMES. How do we turn that auto send? BTW, I'm from the Philippines and using a local carrier called Globe. I don't know if its the phones fault or my carrier. Please help. Thanks guys! <3
~~Karma06
I am having the same issue. I want to change the clock on my lock screen, but there's no option for clocks & short cuts. I tied changing the lock screen to swipe, but it didn't work for me. Any suggestions? Same phone LG optimus g pro
Did you ever figure out how to change clock on the lock screen? I also have LG optimus g pro and don't see options for clocks and shortcuts. Just had update to 4.4.2
sorry if this has been asked/answered but how do I get "press and hold this screen to add more content" of the screen. I don't want to add icons to the screen-just want it blank besides the bottom icons
For some reason, my Touch Keys light up, but they aren't working. They are being used to click on the next closest button to the top, how can I turn them back on? I've been through every setting in my phone and can't seem to figure it out.
Thank you!
Michael Carvalho
