Quick question solved
Ok so I backed up first and then flashed the camera mod v3 no problem. During the flashing process it said "please upgrade update binary" and then after the flash completed I rebooted the phone and when It finished rebooting a message popped up saying "upgrading android". I just want to ask if this is normal and I did flash properly? Did this happen to anyone else?
Re: Quick question
The jpegs will be bigger and that's about the only thing you'll notice, unless you took a photo, flashed the mod, then took the same photo
My M8 posted this
Re: Quick question
My M8 posted this
Yeah I can tell the picture quality is better with the camera mod v3 :)
Re: Quick question
Quick question, In philz touch is it better to do "wipe data/factory reset" or "clean to install new rom"?
Re: Quick question
Depends what you're flashing
My M8 posted this
So for example if I flash gpe rom from arhd rom then would I choose "wipe data/factory reset"? If I flash a sense based rom like viper one from arhd rom then I would choose "clean to install new rom"?
Re: Quick question
Quick question, whenever I try to change battery icon in rom toolbox pro, it keeps telling me "missing icons file was not found on your system." Why is it doing this?
Re: Quick question
I have no clue i havn't used toolbox but maybe you need the icons you want to use on the phone? Like a icon pack
Re: Quick question
What are better ways to change battery icon? I tried xposed statusbar mods and it does not support htc one m8. So what better ways are there to change battery icon?
Re: Quick question
Find some on XDA and flash in recovery
Ok It took some time, but I finally found the perfect xposed modules. Xtended settings and xblast tools. I used xtended settings to hide stock battery icon and used xblast tools to add custom batery icon. There are so many cool features from these modules. I love both of the modules Xtended settings and xblast tools are worth it :)
Re: Quick question
Ok It took some time, but I finally found the perfect xposed modules. Xtended settings and XTools. I used xtended settings to hide stock battery icon and used xtools to add custom batery icon. There are so many cool features from these modules. I love both of the modules Xtended settings and Xtools are worth it :)
Sense 6 toolbox, which you already had, also does both those things
Posted by my Nexus 7 (2013)
Yes I already knew sense 6 toolbox can do that, but I did not like the battery icon from sense 6 toolbox. I prefer the battery icon from xblast tools.
BNIDIRECTt
