Random Screen Zoom/ Blue Border
Looks like I found the problem....
Someone in another forum suggested "Is Settings -> Accessibility -> Magnification gestures enabled?"
That was turned on for some reason. Don't know how or why. After I turned it off, the problem went away.
Correct solution! Thank u
Thanks for the hint on what the blue border meant! I left the zoom on but triple tapped to turn off the behavior.
Thanks for your reply, I'm heading up my settings now to turn off magnification gestures, i dont understand how it all of the sudden got turned on. Anyway thanks for the fix.
Thanks very much for this thread. My dad always manages to activate these features and I will have no idea why his phone will be doing what it's doing. Threads like this make my life easier. :)
Thank you ,same issue little blue square double tap to use ,well went to settings, accessibility, then turned off the speak feature. And it went away ... Ty
I went to fix the settings for mine and there is not magnification option in my accessibilities section of my setting can someone help I have the lg v10
Thank u very much
FahadsTech
