RAZR MAXX HD - Problem with bluetooth profiles
WillyWonka
48
Whenever I pair my phone and use either the DUN or serial port bluetooth profiles, then open terminal emulator it will respond to:
AT
ATE[0 | 1]
AT&F
but I can't get a simple "ATDT" or even "ATD" followed by the phone number to work. It responds with "ERROR" every time.
There is no point to those profiles when it also supports the PAN (Personal Area Network) profile unless you want to send a fax or similar.
Yes, I'm trying to receive a fax at 9600 baud.
I know it would work because I've heard of people doing it before.
It should be responding with "CONNECT" instead. And I should be seeing the call status (on the phone) with the earpiece turned off automatically.
What gives? Any help? :(
Nehasingh12
